Reboot and System Reset
Although I am not familiar with the reset process for the Aurora, I imagine there will be times that a system rest will be suggested or required from a software upgrade. Current 6000 and 8000 series suggest a soft shut down, wait a period of time for the processors to close down, then disconnect the DC power. Then when powering back up depress the power button until it turns white.
As a remote user I can do all the steps except depress the power key. On an Aurora will the user be required to remove the AC plug?
There is currently an API available to reboot a Flex 6000 or 8000 series. I suspect the same API is available to the Aurora series.
How about a modification to thee API to perform a reboot and then invoke the system reset routine? This would allow a remote user to perform a clean install of an upgrade.
In SmartSDR, expand the radio setup menu with Reboot (keep settings) and Reboot (factory reset).0
