DVK and Maestro C
Has anybody been able to get the DVK to play out on a Maestro C, using the Function keys?
When I try to program the keys, it will let me select a specific message, but nothing happens when the corresponding Function key is pressed. The keyer will play from its own configuration page, though. Not at all convenient.
Phil K9UC
Phil K9UC
Hi
This is important to first delete any programmed function F1-F6 for DVK.
To open DVK, to click on Clear for every 12 channels, recording by selecting the channel choice, MOX at On, Record followed by Stop. To use Playback as test (power 1 watt),
Next to select Function F1-F6, DVK a new window will open to select a number. Not the reverse by first creating the DVK Function number
Now unless someone knows how to save DVK with Function, the recorded message is saved but not Function F number. I need to reprogramme the F-key every time I power off the radio.
Rejean va2am
- 116 Aurora
- 323 Shack Infrastructure
- 228 Networking
