Weird DIV Problem with MultiFlex
Upgrade to v4.1.3 went off without a hitch with Maestro C and 6700. I often use my Maestro in conjunction with SSDR in MultiFlex mode. I'm finding that DIV doesn't work on the Maestro in MultiFlex mode. It did work in the previous v4.
What happens is, the DIV child window opens as always but nothing happens. The AG doesn't engage the B antenna either. I performed a full factory reset after updating as always, and performed a second one as well. The second time I didn't reload profiles. With no profiles, the problem didn't occur. But as soon as I created one and saved it, it reoccured.
DIV in SSDR works fine throughout. DIV in Maestro alone works fine. I'm also seeing erratic behavior with ESC - with identical settings all around, sometimes it activates with huge gain, sometimes not.
I anyone else seeing anything like this ?
Thanks ! Russ KR6W
