Radio disconnects from 4.x after installing. Keeps trying. Why?
Flyover
Member, Unconfirmed ✭
I would export profiles, then do a factory reset. If the problem persists, submit a help desk ticket.
After you updated your radio did you do a cold boot of your Flex…in short did you follow this process:
This factory reset worked for a short time, but now my radio is disconnecting again after SmartSDR comes up for 30 seconds.
I went from a fully operational 6600 running 3.9.19 to a paperweight running 4.0.1. Not a great trade, but at least I got to subscribe to SmartSDR+.
I sent in a support ticket, but I bet there are now pretty busy with support requests, if my experience is any indication.0 -
By chance are you running a 4O3A/Flex Tuner Genius, I had this problem with the Radio when I was running version 1.2.10 on the Tuner, I had to update the Tuner to 4O3A's 1.2.17 from their Web site.
If after a hard reset run the radio for a few day with out loading ANY old Profiles, you may have a bad Profile, if you haven't done so yet.
- 688 The Flea Market
- 105 Aurora
- 974 Genius Products
