Mac address
KC3ROS
Member ✭
no success in finding the mac address on a tuner genius. One needs the address with the IP address to create a reserve or static IP address on a router. Thanks in advance for any thoughts.
Advanced IP Scanner and/or Command Line use "arp -a" (no quotes)
A suggestion: Once you use @Geoff AB6BT suggestion, and you find the TGXL MAC address, you may consider making a label to stick on the back with this MAC. It may save you (or later owner) a lot of grief
Thank you @"Geoff AB6BT" for the command line arp -a! Worked perfectly. Thanks @Gord-VA7GP for your recommendation.0
Glad it worked!
- 692 The Flea Market
