APD V4 not calibrating on 20m
wb0z
20M Band - In the last v3 software on my maestro, I would see APD go from calibrating to active after about 15 to 20 seconds of my transmission. But now I can even do 60 seconds and it still shows calibrating. Also it seems all the freqeuncies that were calibrated before are not in memory as it just shows calibrating across the whole band.
40M Band - Justa simple count down from 1 to 10 and it goes from calibrating to active fine.
Is anyone else seeing this?>
Just as an update as I never received any comments nor did my support ticket get a response, but 4.1.3 fixed this issue and now it does calibrate across bands again.
