Command code to switch 6500 between ANT1 and RX A antennas
K2PO
in SmartSDR API
I'd like to program an F-key in N1MM to toggle the RX ANT between ANT1 and RX A (or program one F-key to go from ANT1 to RX A and another F-key to go from RX A to ANT1).
Any suggestions as to how this might be done?
The Elecraft K3 has a CAT code that supports a toggle functionality. I can store the following command in my F11 N1MM key, and the key then toggles the RX ANT back and forth:
F11 TOGGLE,{CAT1ASC swt25;}
Any help appreciated - I've not worked with Flex command codes before.
Tnx,
Bill, K2PO
- 692 The Flea Market
