Maestro C will not connect to Simple Mobile Hotspot
I finally gave up on trying to get around T-Mobile blocking UDP packets. I purchased a Simple Mobile Hotspot which runs on the Verizon network. I connected the Maestro to the Hotspot without issue. When booted, I am presented with the same minimum display, no audio, and no radio control as I did with T-Mobile. However, if I connect both my iPhone 15, and IPad Pro to the hotspot, I get complete access to my 8600.
The maestro connects to my 8600 using my home Wi-Fi.
I would appreciate any suggestions on where to go from here.
Bob, KN4HH
Sorry for the bandwidth on this. If I log out of Smartlink and log back in, I successfully connect and the Maestro works very well. What I don't understand is every time I want to use Smartlink with the Maestro, I have to log out of Smartlink and log back in again.
Bob, KN4HH
possible the Hot spot is grabbing a different IP address and so smartlink needs to reconnect to associate it and pass the connection on to the Radio.
i ended up doing a reset, logged out of Smartlink, and logging back into Smartlink. The connection is now stable and working flawlessly for the past week.
