Strange Occurrence 3.10.10 Install
DonS
Member ✭✭✭
Following the instructions for the install seemed to be pretty straight forward, however, this time after the install I shut everything down, removed the power for a minute then inserted the power cord, turned on the PS and then turned on the radio. The first thing I noticed was that in CAT display all the assignments were showing "Not Present" and when I hovered the mouse over the CAT display it showed it was spinning like it was hung up. I closed out of the SDR app, shut down the radio and disconnected the power source for a minute and then reconnected the power, turned on the radio and started the SDR software and the CAT display showed in blue "Auto Switch TX". Everything appears to be functioning properly.
Don - kx9q
- 688 The Flea Market
- 105 Aurora
