Dax channel reset on DIV?
Rich M5RIC
Rich M5RIC Member ✭✭✭
Hi all
Before I submit a ticket, would like to see if anyone else has this.
Running SmartSDR for Windows, 3.9.19, Slice A with Diversity (DIV) turned on, Slice A DAX is 1, Slice D is set to 2.
Each time I close SmartSDR, the DAX channel is set back to none on Slice D.
Every other slice retains the previous DAX channel, except the one used for diversity.
Thank
Rich
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi Rich… I believe there is already a identified bug with DIV not 'resetting' properly when turned off and leaving things in weird states.
    Hopefully, the next update will address this.
