Flex 5000 & Windows 11
Thanks & 73 de W5XJ
Cell 214-908-6355
EM12ou
Firewire card driver installed? You need to download the last version of PowerSDR from Flex Radio first and install it. The correct Firewire driver is installed when you install PowerSDR. There is a utility from Flex Radio that installed that will let you configure the Firewire card and the driver. Be sure you have the Firewire cable installed correctly. Power on the radio before starting PowerSDR. If you still have problems, it could be the chipset on the card that is causing the problem. Texas Instruments chipset is preferred although the VIA chipset will work. Other than that, the only other thing besides a defective card or radio, would be the Windows Firewall blocking the communication between the Firewire card and the radio. If turning off the Firewall fixes the problem, then you will need to edit Windows Firewall and make an exception for PowerSDR.
OK great. Thank you for the ideas. I'll give it a try. 731
- 688 The Flea Market
- 105 Aurora
