Display does not fill screen vertically
My SDR image for Flex 6700 will not fill the entire laptop screen. This is the case across two laptops and several monitors. The SDR controls are all available but it won’t expand to a full screen from a reduced image. Sorry I’m sure I’m not using the proper terminology. The SDR controls when expanded covers the entire width of the screen but the vertical only fills the top 3/4 of the screen. I cannot “pull” down the bottom. I have the highest resolution and all my other programs will fill the entire screen.
Thank you for any help.
Without knowing more, my guess is that this is related to the screen resolution.
Try maximising using the window control (middle icon above).
Failing that, press and hold the Windows key + M key to minimize all windows.
Press and hold the Shift key + Windows key + M key to maximize all windows, which should include any errant applications.
What happens to the SSDR window then?
I have the same problem and the above suggestions do not work. It has been working and this problem just started.
Can you grab the lower right corner with your mouse and drag the form towards the lower right of your monitor? I have had that happen in the past and it worked for me. Otherwise, the suggestion about screen resolution might be something to check out.
