Maestro B & 8600 - 2 slices - anyone having issues setting receive ANT
Running v3.9.19, I am having issues when running 2 slices. When I change RX ANT on either slice, both slices update the RX ANT. This does not occur when I run SmartSDR for Windows. I am able to select different RX ANT for each of the 2 slices. The TX ANT is to ANT1 and ANT2 for each slice respectively.
Is this a known issue with the v3.9.19 on the Maestro?
I also have PGXL(v3.8.9) and TGXL(v1.2.11).
I typically use my Maestro in SmartControl mode. So, I just noticed this issue today when I attempted to use the Maestro to monitor 2 different bands while do some other work on Windows computer.
Thanks,
Eric - NR4O
Each slice needs to be in separate panadapters. The antenna is global for that p[anadapter.
In the bottom of the Maestro panadapter is an arrow you tap which creates a second panadapter. Tap B until it moves to the lower panadapter
73Dave wo2x
- 692 The Flea Market
- 119 Aurora
