Download Frustration...
pinrod
Member, Unconfirmed ✭
Hi!
I have a Maestro and 6400. I'm trying to download CAT command information unsuccessfully. It seems that every link on any reference page sends me back to an identical page (as a local link?), but doesn't just give me the documentation I'm looking for! Anyway, I'm wanting to write a custom script to control the radio (specifically, to put two different slices into different sides of the stereo right/left automatically). So, could someone supply a simple link instead of this apparent endless circle? I am a bit (!) frustrated. It just shouldn't be this hard! (or is it me??!!) k WB9FMC
Here is a link to the document:
Len, Et Al: Thanks! k WB9FMC0
You're welcome! Another thing to consider is the Flex API. CAT provides a bit of functionality, but the API over Ethernet has access to the entire command set. If you find that you want to do things that are not supported by CAT, the API will be the way to go.
- 688 The Flea Market
- 105 Aurora
- 974 Genius Products
