Programmable Function Key Assignments
pinrod
pinrod Member, Unconfirmed ✭
On the 6400, is it possible to create functions not listed in the Maestro drop-downs for that reason?
Thanks!
kurtt WB9FMC
  • Erik Carling EI4KF
    There is an extensive list available but outside of it, no you cannot add your own. You would need to use 3rd party s/w or h/w depending on your requirement.
  • pinrod
    Eric: Thanks! I guess it'll have to be that! {'-)
