update not working
Did the shut down, remove power then turn back on after a couple minutes. Started the installer and it ran through the usual install questions. Then the install screen with the progress bar just went away. I checked task manager, nothing.
Figured I would check here before a help ticket.
Greg
AB7R
I had to run installer in compatibility mode. Update complete and working fine so far.
Contrary to someone's earlier post about APD….It can be active in Data modes but doesn't seem like it is doing anything. Same with CW.
Thanks again Marvin!
Hi Greg, APD only has any effect on modes that have more than one simultaneous tone, like speech (SSB, AM) or multi-tone digital. FSK (one tone at a time) or CW don't benefit from it. They can already use a non-linear amplifier cleanly. In the old days, we ran class C amps for CW and RTTY and class AB for SSB. APD has the effect of "linearizing" your finals for modes that need linear operation.
