CWX - saving macros to Global Profiles
I believe this was working in the previous version. I can't seem to get my macros to stay in a Global profile. Here is my test:
I'm on 20m cw
Set cw speed to 25wpm
Enter "test1" under F8 in the CWX window.
Save Global profile as "20m test1".
Now change the cw speed to 30wpm and
change F8 to "test2" in the CWX window.
Save Global profile as "20m test2".
Now when I load 20m test1, F8 still shows "test2", but it does change the cw speed to 25wpm.
If I load the 20m test2 profile, again the F8 still shows "test2" and the cw speed changes to 30wpm.
if I select Band and select any band other than the one I'm current on and then select one of my created profiles, F8 is blank and remains blank whenever I select either of the newly created profiles.
What am I doing wrong? Autosave is disabled, but I'm pretty sure I had it enabled originally and it was doing the same thing.
Running version 3.9.18
Peter - WB6POT
