Trying to operate my FLEX-6600 with SPE Expert 1K-FA
johna8119
I have used this combination for several years now, but after disconnecting and reconnecting the 6600 for an SD card replacement, I can't get the amp to transmit when I key the xcvr. (Yes, I do have the amp in operate mode.)
I have Dan Tassel's cable between the devices, with the USB and TX1 connectors appropriately positioned. But I can't remember the other rear connections. Specifically, where does the Relay connector on the back of the amp connect to the 6600?
Tnx. John W4KV
So I referred back to a previous post of mine. I simply needed to check the bands for which I wanted the xcvr to key the amp. I do have the cables properly connected. Maybe the new SD card deleted the Tx Profile info?
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
