Please help! DXLabs with WSJTX, JTAlert and 8600
I followed the directions in:
But when I have two instances of WSJTX open when I change frequency from one they both change. If I click a decoded call in A both slices in SSDR move to the same frequency as does WSJTX and DXL.
I know I am close but pulling my hair for past 3 days trying to get this right with no luck.
Then I need to integrate JTAlert….oh boy!
Tnx
Greg
Hi Greg,
There is a great way to get super high quality help directly from the developer of DXLab Suites, Dave Bernstein. Sign up (for free) for the DXLab group at groups.io (https://groups.io) and submit your question. His support is a great as his software - and that's saying something.
GL Russ KR6W
tnx! Already left a message there.
Hi Greg
Long day! Just got home from Dayton (back in NJ)
Looks like you have both A and B set for same TCP COM port. In CAT you want one TCP com port on slice A and a different TCP COM port for B.
I would suggest then using a program such as JTAlert as middleware between the two instances of WSJT-X and DX Labs. In JTAlert there is a setting under logging to use DX Labs.
and I’ll second the comments support for DX Labs from Dave is top notch. And free!73
The couch is calling my name….
Hi Dave. I spent a few hours setting up with WQ6Q who is using this setup. The problem was Dave insisted on using the DXCommander protocol in WSJTX. Instead we used the Flex Slice A to Slice D protocols which then treats each slice as a separate radio. He then showed me how to setup JTAlert as I had no experience with it. No I can run 4 slices - 4 instances of WSJTX and 4 corresponding instances of JTAlert. All seems to be running well. Hope you got some rest!!! I am going to try to go next year.
- 117 Aurora
- 323 Shack Infrastructure
- 228 Networking
