Audacity
Opathy
Opathy Member ✭✭
Im having trouble making recordings with my 8600 using Audacity. I'm using Dax but the recordings are distorted like the sample rate is not right. Will Audacity work with SmartSDR number one and is there another way in SmartSDR to record a signal and save it as a file?
  • Rich M5RIC
    Rich M5RIC Member ✭✭✭
    If its distorting check the levels in audacity are not too high on the input.
    I use it to record CQ messages for contest loggers and have no issues at all.
  • Opathy
    Opathy Member ✭✭
    I’m trying to use Audacity to record stations that I’m receiving.
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    In Audacity, I assume you have one of the DAX Audio RX channels selected and you have the same on selected inSSDR and that DAX is enabled.
    On the menu bar, there is an audio level meter. Is says "Click to Start Monitoring". If you click it what does the meter indicate?
  • Opathy
    Opathy Member ✭✭
    I have all set like you said and I have plenty of level. ITs just very distorted like their are not enough buffers
  • Opathy
    Opathy Member ✭✭
    Retried again this morning and the distortion is gone. I who knows, maybe it’s the order in which I started the programs.
    Thanks all for the input
