Band Edge
Glenn Depp
Is there a way to turn off the Band Edge notification. I get a beep every time I slide past the edges of Amateur Bands. This did not occur in the previous SmartSDR updates that I can recall.
Do you happen to be using FRStack? That has an option for band edge beep. I do not get a beep from SSDR and I believe there is not any option for it within the SDR software (could be wrong…)
Erik
That may be my problem. Thank you very much. I do use it but ONLY for the squelch functioning.
There is no band-edge beep in SSDR.
The issue was FRStack3.
- 685 The Flea Market
