TGXL remote operations (1x3 Model)
KG5PTE
Question 1. Is there a iPhone app to control the TGXL remotely ? If not is there going to be one developed ?
Question 2. Since my Flex 6400 Ant-1 jumper goes to the input of the TGXL (1x3) and Ant-2 on the 6400 is on a dummy load. (Not used) My Hex beam for 10 through 20 meters is on ANT 1 on the TGXL and my 40 m & 75 m Alpha Delta Dipole are on ANT 2 on the TGXL. How do I "remotely" switch between TGXL ANT 1 & 2 ? This is were Teamviwer comes into play I guess or Anydesk. When traveling using my iPhone 14 Pro to access my Flex 6400 I said wait a minute how can I switch antennas now to go from 14.290 MHZ on 20 m to 7.213 MHZ on 40 m ? Because I need to put the TGXL on Ant 2 now.
Thank you.
- 104 Aurora
