GNSS warmup time
Best Answers
In order to get a clearer view (SW sky) I have the GNSS located on a short wooden pole about 4 feet from the house. I've always seen perfect signals/performance on my 8600 (and the 6600 before it), regardless of weather. Any chance to get a better sky view at your shack? With the antenna on a window sill, the house may be blocking more than 50% of the signal. I had to buy an extension cable (15' GEMEK from Amazon)…works like a charm.
are there any trees outside the window? That will reduce the signal and visible satellites.
Can you try moving the antenna to the top of the bottom window half near where the latch is? I did that here but a pain in better weather if I open the window.
I did extend the cable and moved the patch antenna outside.0 -
I have the antenna outside it se 16 sat but no lock. I did not se this in 3.8.23 so i suspect its a sw issue. It was not super fast to lock in 3.8.23 but it did lock Yeasterday i waited 7 hours warming up. no Lock ........
Try performing a factory reset as described in the release notes. I had no problems on 3.8.23, but after upgrading to 3.9.18 the status was "Warming Up" and Latitude, Longitude and Sat Tracked were zero no matter how long the radio was on (Sat Visible was usually around 15). After the reset, status changed to Locked after about 30 minutes.0
Since acquiring the 8400M, about a month ago, the GNSS has locked within 5 to 10 minutes of powering up. No problems every day until 3 days ago. Now I do not get a lock. Within 5 to 10 minutes I get a solid yellow light and the Status is reported as below:
The NTP time server is running. As for frequency correction, the radio only reports TCXO lock and not GNSS lock. Altitude is not correct as I am 210m and when it locked before that was what was reported. Usually the radio is on for around 12 hours a day and is in the Free Run state all that time except once briefly during the past 3 days I saw Status change to Pull In.
I always have 20+ visible satellites, often over 30, but no longer see any tracked. If anyone knows what Free Run means and how to make it lock again I would be pleased to know. I have tried all of the following without success so far: factory reset, moving antenna (it is outside and has no obstructions but of course movement is limited by cable length), and disconnecting and reconnecting the antenna.
Erik.
my Icom HT locks up within a minute or two but the 8600 even with 13 satellites won’t for hours if at all. It seems the receiver is pretty insensitive
Thank you. You may be right and I have ordered a replacement GNSS antenna with pre-amplifier.
Erik.
Just for comparison, here are my observations…. 8600 turned on from a cold start:
Timed from when the Start button turns steady green:
At 45 seconds "Pull in" with about 20 sats, and a 109 ppb.
At two minutes 8 seconds, "Locked" happens (24 or 25 sats).
I use a 15-foot extension, non-amplified cable to an outside sat antenna on a 4-foot high stick in the ground, SW exposure (north exposure blocked by house, east blocked by a really dense Colorado Spruce).
Yes Jim thanks, interesting. I do not know why I've had no issues at all for 4 weeks and now no lock. Something has changed - maybe the supplied antenna has failed. I had it in a plastic bag and it had not got wet. I took the radio outside yesterday and taped the puck to a pole - it was in the clear before anyway but was near the house wall - so in this test it was ultra clear. Still no lock, only 'Free Run' with 32 satellites seen, 0 tracked. Anyway new antenna on the way.
I received a new 8600 yesterday. I fired it up today. It took about 6 hours for the GNSS to go from warm up to free run and then a few minutes later it locked for a few minutes. Now its back to free run. 15 Sats visible.. Sat tracked=0.
THis morning I switched the 8600 to SSDR for the Mac and the power light turned solid blue and 5 hours later is still blue. I'll have to switch it back to the PC and see if it remains blue.
My new 8600 came with the GNSS module that I didn't really want or need already installed. It's a big job and not worth my effort to get the GPS antenna out in the open, so for giggles I just set it on top of my 19" rack, indoors with no view of the sky.
To my surprise, the module is seeing around 16 satellites and has picked up UTC time OK. However, it never gets past warming up status and does not show lat/lon, etc. Meanwhile, the little yellow GNSS light flashes away, imperiously reminding me that its master is not a happy bunny.
I really have no need of the GNSS facility but there seems to be no way to disable it in the SmartSDR configuration. It is likely that it will get ever past the warming up state, or is the flashing yellow light going to be gently irritating me for ever more?!
73, John
My new GNSS antenna with preamp solved my problem. In fact I can even have it inside the house. However it is fair to say that many have no trouble at all. Maybe geographic location has a bearing on it, with western Europe locations needing more signal to the module? That said, to me who knows nothing about GPS modules, it is somewhat incongruous that a high number of satellites can be reported, sometimes as many as 32, but there is no lock with the supplied antenna. The replacement antenna can see far fewer satellites but does lock within 5 minutes.
Interesting Eric, thanks. On a whim I strung a coax across the shack to a nearby window, put the supplied antenna out on the window ledge and it almost instantly locked, solid blue light, happy GNSS module. It even reminded me what my locator is!
As you say, strange that with the antenna indoors it can see a surprising number of satellites but apparently not lock. There'll be an explanation for sure but like you, my GPS knowledge is not up to the task.
That said I really have no need of it at all and just wanted to stop the yellow LED winking at me. Strange that there is no option to disable the GNSS functionality if not needed.
When I switched back to SSDR on my PC the blue light remained solid blue. So far my 8600 has stayed locked to a satellite after over a day.
I have a 6400 with a GPSDO in it and that has an option to disable it. When I got my 8600, I too was surprised there was no way to disable the GNSS.
My 8600 came with a "puck" with about a 6 or 10 foot cable for the GNSS antenna.
Well I shut my 8600 down to rearrange the shack a little. It been 6 hours since turn on and GNSS is still warming up.
I have submitted a ticket requesting the ability to turn off GNSS functionality and remove the associated "LED" from the SmartSDR display.
OK, well here's my experience…
I have the "shack" in a corner of our garage. I have my GNSS antenna on a window sill and about a foot above ground level. There is a redwood whose trunk is about six feet from the window. The antenna is beneath the tree canopy,
Typically there are about 20-25 satellites visable and 8-12 tracked.
I haven't timed it,but the panel LED turns blue in about a minute after power on.
I wonder why there is so much variability in the ability to acquire satellites?
John G3WGV - I hope this happens. For those of us who are challenged to get a GNSS lock, this would be great.
When I came into the shack this morning, the pulsing yellow is now solid yellow and status is free run.
I'm trying to avoid an outside antenna
I think it's more a case of understanding how satellites come to be "tracked". Most of us get plenty of satellites visible, even with an indoor antenna, but they never get tracked. When I put the antenna outside I almost immediately get enough tracked satellites to keep the radio happy. I guess it must be a signal strength thing.
Here is the feature request to turn of the GNSS functionality. Head over there and give it an up-tick if you are so inclined.
After almost a day and a half mh GNSS locked. As suggested, probably marginal or weak signal.
Anyone know what "warming up" really is, particularly when it takes at least a half a day or more? I can understand a long time to lock after warming up if satellite signals are weak.
When Google was asked "will GPS signals **** low E glass"
Yes, standard glass lets GPS signals through, but Low-E (low emissivity) glass, with its thin metallic coatings, can significantly weaken or block GPS signals because these coatings interfere with the ultra-high frequency radio waves GPS uses, causing signal attenuation (loss) that can prevent your device from getting a lock. While sometimes they work, you'll often experience dropped signals or long acquisition times near Low-E windows, especially in modern buildings.
Why Low-E Glass Blocks GPS:
Metallic Coatings: Low-E glass has a microscopic metallic layer to reflect heat, but this layer also acts as a Faraday cage for certain radio frequencies, including those used by GPS (L1 band).Signal Attenuation: The coating reduces the signal's strength (measured in decibels, dB), making it harder for your weak GPS receiver to lock onto the satellites.
How to Know if You Have Issues:
In a Building: You notice poor reception inside near windows compared to the strong signal outside.Solutions & Workarounds:
External Antenna: Use an external GPS antenna or a signal repeater system for buildings.Different Window Type: If possible, opt for glass without strong Low-E coatings.
I learned this lesson the hard way when moving 2.4GHz WiFi link between and old ski lodge and the summit. Everything worked great in the old ski lodge with the WiFi access point placed inside the ski lodge behind a window facing the summit. Once the same WiFi access point was moved to the new ski lodge pointing at the same WiFi access point on the summit the system failed for no explained reason. After several trips to the site it was finally determined that the new "modern" low "E" glass in the newly built ski lodge was the culprit.
So if your shack is of newer construction and setting the GPS antenna on the window sill doesn't seem to work check to see what type of glass is in the windows.
That's odd that the word **** in the Google question got changed to four "****".
Hmmm, I guess the Flex community doesn't like a common English word that means to go into or through???
