Does SSDR/DAX/CAT work on Snapdragon ARM Windows 11 machine?
I'm thinking of purchasing a new Microsoft Surface laptop with Snapdragon ARM Processor. I specifically want to use the laptop for SSDR with DAX and CAT. Hopefully with better performance than with my old surface. In older posts the answer is no. Does anyone have an update? Does this work? Is there anyone who has done it?
Thanks,
Paul
N0GN
SSDR for Windows may run on an ARM machine, but the DAX and CAT/VSP Drivers are not ARM-compatible, so they will not run on an ARM machine.
OK. Thanks
I'm considering replacing my Surface Pro i7 with one of the newer Surface models. It looks like I'll need to go with the business line, since those come with the Intel Core Ultra processors. Does anyone know if there's any forecast for a DAX/Cat version using Snapdragon?
