DAX Muting During FDX Transmit
Jim KJ3P
Member ✭✭✭
Here's the deal: 8600 in Full Duplex mode. Receive slice set to DAX1.
Problem: DAX1 mutes during transmitting.
I'd really like to be able to record the RX slice with Audacity using this setup. What am I missing?
Best Answers
Here is a video which should help
I forgot about the trick of using an XVTR output as TX. Thanks for the reminder!
I am using the transverter port on my 6400 (for a transverter, of all things… 😁), so I keep a 50 ohm dummy load on ANT2 for just this purpose. My Flexicraft utility automagically sets the power out to 1 watt whenever I set the TX antenna to ANT2 on the TX slice.
