Slicemaster questions
philblade
Member ✭
A couple of questions :
a) In the mixing tab, the image of the mixer is very small and is difficult to read, How do i make this larger?
b) I can get CW Skimmer to launch from the LAUNCH tab when pressing the 'CW Skimmer' tab' for both slice A and B but WSJTX does not execute.
Config ini
[slice_A]
gritty_launch = never
gritty_tx_on_click = True
gritty_select_on_click = True
cw_skimmer_launch = when_active
cw_skimmer_tx_on_click = True
cw_skimmer_select_on_click = True
cw_skimmer_rit_on_click = False
cw_skimmer_xit_on_click = False
hrd_listener_enabled = False
hrd_listener_port = 7811
cat_listener_enabled = False
cat_listener_port = 7821
WSJTX_identity = Slice-A
JTDX_identity = Slice-A
JS8CALL_identity = Slice-A
MSHV_identity = Slice-A
MMTTY_identity = Slice-A
hrd_listener_auto_tx = switch
cat_listener_auto_tx = switch
cw_skimmer_launch_on_cw = True
WSJTX_launch_jtalert = False
WSJTX_launch_on_digu = True
WSJTX_launch = when_active
[slice_B]
hrd_listener_port = 7812
cat_listener_port = 7822
WSJTX_identity = Slice-B
JTDX_identity = Slice-B
JS8CALL_identity = Slice-B
MSHV_identity = Slice-B
MMTTY_identity = Slice-B
LOG FILE
2025-02-04 16:31:04,737 INFO wsjtx.launch Starting WSJT-X slice='A'
2025-02-04 16:31:05,472 DETAIL wsjtx.launch adjusting truncated audio device name device='DAX Audio RX 2 (FlexRadio Syste'
2025-02-04 16:31:05,589 DETAIL wsjtx.launch adjusting truncated audio device name device='DAX Audio TX (FlexRadio Systems'
2025-02-04 16:31:05,603 DETAIL wsjtx.rewrite_config Clock is within tolerance clock_error=4
2025-02-04 16:31:05,609 DETAIL wsjtx.launch Ready to read spots from path='C:\\Users\\philb\\AppData\\Local\\WSJT-X - Slice-B\\ALL.TXT'
2025-02-04 16:31:05,610 INFO hrd_listener.listener Listening for HRD TCP connections. port=7832 slice='B'
2025-02-04 16:31:07,623 DETAIL simple_ntp.clock_error err=OSError()
2025-02-04 16:31:07,696 INFO wsjtx.launch Starting WSJT-X slice='B'
2025-02-04 16:31:14,050 DETAIL flex.flex.Flex6000.tote_board tote='spot' tally=39
2025-02-04 16:31:14,050 DETAIL flex.flex.Flex6000.tote_board tote='slice' tally=2
2025-02-04 16:31:24,106 DETAIL flex.flex.Flex6000.tote_board tote='spot' tally=41
2025-02-04 16:31:34,110 DETAIL flex.flex.Flex6000.tote_board tote='spot' tally=51
2025-02-04 16:31:44,961 DETAIL flex.flex.Flex6000.tote_board tote='spot' tally=49
2025-02-04 16:31:55,098 DETAIL flex.flex.Flex6000.tote_board tote='spot' tally=31
2025-02-04 16:32:05,727 DETAIL flex.flex.Flex6000.tote_board tote='spot' tally=33
2025-02-04 16:32:15,901 DETAIL flex.flex.Flex6000.tote_board tote='spot' tally=27
2025-02-04 16:32:26,080 DETAIL flex.flex.Flex6000.tote_board tote='spot' tally=36
2025-02-04 16:32:36,107 DETAIL flex.flex.Flex6000.tote_board tote='spot' tally=50
2025-02-04 16:32:46,111 DETAIL flex.flex.Flex6000.tote_board tote='spot' tally=49
2025-02-04 16:32:56,638 DETAIL flex.flex.Flex6000.tote_board tote='spot' tally=42
2025-02-04 16:33:04,887 ERROR wsjtx.terminate WSJT-X process never connected. slice='A'
2025-02-04 16:33:04,888 INFO hrd_listener.listener No longer listening for HRD TCP connections. port=7831 slice='A'
2025-02-04 16:33:04,888 INFO wsjtx.terminate Closing WSJT-X process. slice='A'
2025-02-04 16:33:06,689 DETAIL flex.flex.Flex6000.tote_board tote='spot' tally=18
2025-02-04 16:33:06,689 DETAIL flex.flex.Flex6000.tote_board tote='slice' tally=1
2025-02-04 16:33:06,913 ERROR wsjtx.terminate WSJT-X process never connected. slice='B'
2025-02-04 16:33:06,913 INFO wsjtx.terminate Closing WSJT-X process. slice='B'
2025-02-04 16:33:06,913 INFO hrd_listener.listener No longer listening for HRD TCP connections. port=7832 slice='B'
Config ini
[slice_A]
[slice_B]
LOG FILE
Just to add to my question, wsjtx is installed in the correct file location on my laptop per the ini file
exe_path = "C:\WSJT\wsjtx\bin\wsjtx.exe"
exe_path64 = "C:\WSJT\wsjtx\bin\wsjtx.exe"
startup_options =
append_slice_label = True
spot_filter = None
fix_truncated_win10_audio_device_names = True
launch_delay = 3
udp_server =
allow_fake_it = True0
- 694 The Flea Market
