Rack suggestions
GM,
Can anyone suggest a Rack that I can put my flex gear in? I have the 6600, PGXL, TGXL, a power supply, and I would like to put a GB switch in the rack as well. I would like to put the rack on the floor or on the desk.
Also, a solution that is okay as far as heat and noise from Amp fan. Any problems of RFI affecting a network switch? I hope someone has already walked this path so I can simply follow it.
Fred, AE4ED
I ended up buying one of these
I use a full length shelf so I can attach it to the front and rear rails to handle the weight of the PGXL. I ordered a few 14" cantilever 1u shelves for everything else.
The rack is deep enough where I have the Flex equipment mounted on the front and Ubiquiti dream machine router and power **** on the back.
Rich - N5ZC
Rich, I just came to ask the same question - how is this working out for you? I have the same setup minus the rack. Would you recommend this rack to them?
Thank you,
Jason KD9ZHF
- 409 Community Topics
- 705 The Flea Market
- 206 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
