WiFi or Ethernet?
HB9DDS
HB9DDS Member ✭✭
Hello together
How do I know what I am connected to with Flex 6xxx? Where can I look this up or switch/define it?
Daniel
HB9DDS
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    The easiest way is to connect the pc directly to the flex, bypassing the network. Or turn off Wi-Fi in the pc (if a pc is being used!).
  • HB9DDS
    HB9DDS Member ✭✭
    This is MY Installtion:
    Daniel
    HB9DDS
  • David Decoons, wo2x
    That configuration works.
    The radio sends out UDP discovery packets. Both the Maestro and SmartSDR watch for these packets and show the radio in the chooser screen.
    If you want to identify the radio in your router, you can get the radio’s MAC address from the Maestro menu then network tab. Or from SmartSDR settings/network.
    73 Dave wo2x
