Rig Expert 600 PS question
I thought , probably mistaken, that a Rig Expert would auto recover back to the on position after a loss of commercial AC power and the Home generator kicked in. Well… I must have missed a setting in the firmware to help that happen? I only changed the output voltage to 14.4V before installing in the remote shed. The PS can be set to auto recover correct?
  • David Decoons, wo2x
    Hi Larry.
    Yes. Go to Settings then 600 Srttings. Second line down, Restore Outputs on Mains Return.
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    Thanks Dave , I missed that in the rush to get it installed and set the vltg a bit higher I guess! Nice power supply and a great feature to have in a remote location.
    Larry k1uo
    yes. Mine is connected via USB to a smal Lenovo ThinkCenter i5 PC in the cabinet. I can Remote Desktop in and check PSU.
    I also have the LP700 with four sensors in the cabinet connected to the ThinkCenter. I use a program called Virtual Here to extend the USB to my shack desktop where I cal run the LP700 app.
    73 Dave wo2x
