New HelpDesk Article re: Setting Up MMTTY for FLEX-6000/8000 Radios
Ken Wells
Ken Wells Community Manager admin
Here is the link to the "How To" article for MMTTY
Configuring MMTTY for the FLEX-6000/8000 Radios – FlexRadio
«1
    Hi Ken, thanks for this and the MMSSTV article. Very informative and well written!
    I do have a question; why is it important to uncheck the Use Low Latency Filters for Digital Modes? I haven't done a lot of digital lately, but am planning on trying out the new RADE mode of FreeDV. I have unchecked the box now, but am curious what the real effect of it is.
  • Ken Wells
    When using the "Low Latency Filters" mode, it rolls off the low and high end frequency response a little, which may be a problem with certain digital modes.
    For MMTTY and MMSSTV it probably would not make a difference.
    Ah, OK thanks Ken, I appreciate the info.
  • IK8HCG
    IK8HCG Member ✭✭
    I own the Flex-6400 Basic version (4.1.5) and followed Ken's instructions for setting up MMTTY step-by-step, but it isn't decoding, and I'm getting a TX stream error.
    what's wrong
    1.png 365.7K
    2.png 416.6K
    3.png 466.1K
    4.png 412.1K
  • Ken Wells
    I strongly recommend upgrading to SmartSDR v4.2.20 and using the new DAXv2
    SmartSDR v4.2.20 Release Notes – FlexRadio
    Adapting to the New Version of SmartSDR with DAXv2 – FlexRadio
  • IK8HCG
    IK8HCG Member ✭✭
    Your excellent user guide is dated 2024, predating DAXv2. I am a user who hasn't subscribed to any options, other than the one from many years ago for SSDR v3..
    Lou IK8HCG
    Hi Lou, to get the latest bug fixes as well as the latest DAX, you should upgrade to V4.2.20. It is a free upgrade and you will retain whatever features that you previously purchased (V3.x).
  • IK8HCG
    IK8HCG Member ✭✭
    thank you, I will try to remove 4.1.5 and install 4.2.20. I will update myself if i ll get any problem
  • IK8HCG
    IK8HCG Member ✭✭
    edited October 1
    I installed the new Basic version 4.2.20. I first removed the old version 4.1.5 along with related files using Revo Uninstaller, and then installed version 4.2.20.
    Question: Before the uninstallation, the old DAX drivers from version 4.1.5 were still listed in Device Manager. Did this new version overwrite the old DAX drivers?
    1.png 151.6K
  • Erik Carling EI4KF
    Using Revo might not touch the Flex Control Driver. Flex Radio themselves show the full uninstallation method in this document: https://helpdesk.flexradio.com/hc/en-us/articles/204975589-How-to-do-a-Complete-uninstall-of-SmartSDR-for-Windows-from-your-PC?_ga=2.181197479.1294798015.1563818469-389851926.1563818469
    This is for versions before 4.2 and is therefore relevant for your 4.1.5
  • IK8HCG
    IK8HCG Member ✭✭
    If I run this string, I find only "Flex VSP" inside "Flexradio system," and within that, I find the "Flex VSP installer."
    C:\Program Files\FlexRadio Systems\SmartSDR vA.B.C\[32 or 64-bit] Drivers\FlexControl
    1.png 74.5K
    Oh, that comes from using Revo - a bad move. Mike VA3MW will hopefully see this and give the definitive answer. If it were me, I would reinstall 4.1.5 and then properly uninstall it using the Flex recommended method. The reinstall will put back the uninstaller and that, when invoked during the the documented procedure, should cleanly remove the old DAX end points. But that's just me. You could even open a Help Desk Ticket and get real advice.
    I haven't read the entire thread, but Erik is correct. Our installers are pretty good, but if you get it messed up we can sort it out for you.
    I have learned that using Revo has some bad consequences at times. It is like using a sledge hammer. :)
  • IK8HCG
    IK8HCG Member ✭✭
    I followed the entire re-installation procedure opening a ticket and getting help from Ken Wells to correctly install version 4.2.20 (Basic) after completely removing version 4.1.5, however, I simply cannot get it to work with MMTTY. SmartCAT works, but the program it self isn't decoding anything. no RX streams but ready in blu color in slice A
    Two questions: Do I need to re-enable Core Isolation?
    And are you sure that MMTTY being an older program actually works with DAX v2?
    tnx, then I give up
    edited October 4
    Core Isolation is irrelevant to the MMTTY question and its disablement is not required for SSDR 4.2, therefore you can re-enable or not as you wish. In some versions of Windows, once disabled it can only be re-enabled if Virtualisation is turned on in BIOS first. Personally I don't give a hoot about it one way or the other. What is more important is LSA and VDB. Prudent settings are these:
    MMTTY works perfectly well here with DAXv2 + SSDR or AetherSDR. So, yes it does work.
    In case it helps, in SmartCAT you do not have a PTT port defined. MMTTY is occupying a CAT port whereas it should be using a PTT port. Change or delete/add in order to create a SmartCAT port thus:
    After it is created, define it in MMTTY Options>TX>PTT & FSK so that the relevant section looks like:
    Your port number will vary.
    The result is:
    a perfectly working MMTTY in 4.20 DAXv2 on TX.
    Now, you also mention that there is no decoding. But check the veracity of that statement. The colours in DAXv2 vary from the original DAX. When there is no connection to anything, the RX Stream button for Slice A is blue. When a client connects, MMTTY in this case, the button changes to green.
    The picture demonstrates that the MMTTY waterfall is receiving mark and space tones and IV3IPA is being decoded. Therefore, a perfectly working MMTTY on RX.
  • IK8HCG
    IK8HCG Member ✭✭
    https://helpdesk.flexradio.com/hc/en-us/articles/49227704037019-Configuring-MMTTY-for-FLEX-6000-8000-Aurora-Radios-with-DAXv2
    Hi Erik, and thanks. That step wasn't performed in your first two photos. I followed the attached description step-by-step, but I will follow the instructions you showed me. In any case, CAT between SSDR and MMTTY is working fine for me. Could I ask you—if you don't mind, and to help other users as well—to attach a series of screenshots showing the settings?
    Hello. What are you telling me? I do not understand your picture. Why would you want to send radio commands? There are three components required: input, output and PTT. Anything else is codswallop.
    Let me see what happens when you follow my instructions. Either you will have success or else I will be branded an idiot, if I am not already. If the latter, a series of screenshots will make matters worse. So let me know how it goes first.
  • IK8HCG
    IK8HCG Member ✭✭
    edited October 4
    The "PTT FSK (none)" image is taken from the FlexRadio DAX v2/MMTTY user guide.
    My problem is definitely explaining myself in English; I left Essex, UK, 40 years ago. My MMTTY works with SSDR and follows the frequency; I have no CAT issues the frequency on SSDR is read by MMTTY and vice versa. I followed the FLEX instructions and configured the CAT settings in Radio Command.
    OK, well 'beam me up Scotty'. I prefer my method as described above because it works and I showed the proof. Having the setting you were using is, in my opinion, the root cause of your trouble. But hey, go with what you feel is best.
  • IK8HCG
    IK8HCG Member ✭✭
    edited October 4
    No, no, no I want to get MMTTY working. But if FlexRadio provides a user guide, people will read that instead, don't you agree? Right now, I’m handling the setup just like in your photo. Do I need to run anything in "Radio Command," or should I leave it as currently set? Then I'll check those two parameters in Core Isolation.
    this is the Core isolation window (i use win10 pro), If I ask to activate it, it tells me it's impossible.
    I'll try your suggestion for PTT FSK now.
    1.png 258.8K
    2.png 296K
    Do you need radio command? I do not show it because I have a working MMTTY without it. You only need input, output and PTT. I hate to be prescriptive but I think you should do only what I said and then test it. There is no reason why, if you follow my answer to you, that you should not have TX/RX/PTT and hence MMTTY working perfectly.
    Core Isolation: as I said it will not activate because it requires a change of BIOS setting. My opinion: forget it. But, if you must have it, you will need to go into your computer BIOS. Please do not ask me about that as there are too many BIOS types and too many different names for the same thing: Intel VT-x, Intel Virtualization Technology, AMD-V, or SVM Mode and others under CPU/Advanced settings.
  • IK8HCG
    IK8HCG Member ✭✭
    Initial setup based on your instructions completed.
    I'm switching to MMTTY and following your suggestion.
    In Radio Comand, I had to set it to (None); otherwise, SSDR would automatically switch to TX mode.
    Now I move on to the audio, setting DAX1 under the VFO window and selecting RTTY mode. In the vertical side panel, I select the RTTY default setting and activate DAX.
    It gives me an error saying it can't open sound card 5, and then MMTTY stops following the band change.
    I’ve done everything (you suggested), and yet it is, or should be easy.
    It means I’ll keep using my old Flex3000 with PowerSDR and MMTTY, where VSPE and VAC never gave me any trouble.
    Thanks anyway for the time you spent on this, but I don't know what else to do.
    1.png 679.5K
    1.png 524K
    1.png 507.3K
    1.png 500.8K
    1.png 406.2K
    edited October 4
    I know what is wrong but I cannot say why. The DAX 1 button is blue and it should be green. It reports 'ready' instead of 'Streaming'. Just look at this tab to see if it is the same, specifically sections Sound Card, Device Identifiers and Sound loopback. If they are the same, DAX error investigation required. I'm sorry I could not help.
  • IK8HCG
    IK8HCG Member ✭✭
    edited October 4
    Erik, you’re too kind with your support, but don't waste any more time; sooner or later we’ll sort this out that’s the beauty of radio. Two other hams in our FlexRadio Telegram chat are having the same problem, and surprise, surprise they’re using Windows 10. Coincidence? I’ve ruled out conflicts with version 4.1.5 which I hadn't uninstalled properly, because everything related to the previous version is gone.
    I’ll keep using my old Flex3000 with VAC and VSPE; it has always worked perfectly with MMTTY right from the start. I even created a user guide that was published on the DXlog website:
    https://dxlog.net/sw/files/utilities/PowerSdr-DXlog-Rtty%20setting.pdf.
    Heartfelt thanks, and I’ll see you in the AESDR area. there is an update version
    The problem lies here: when the DAX API is closed, I get this error when launching MMTTY.
    1.png 447.1K
    1.png 229.5K
    With the DAX applet open, the blue Slice A button should turn green when MMTTY is launched. I do not think the issue that you have relates to Windows 10. Although I now use SDC everyday RTTY module and SDC Contest module, I have MMTTY as my go-to back up software for RTTY is case of emergencies. I have used the program since year 2000 when it was first launched as "MMTTY-RTTY". It has worked on all versions of Windows since then including Windows 7, 8, 10 and 11. I have used it with Flex since 2021 without any issue.
    I read that Flex document, the link for which you showed me. I must confess that I could not agree with it. I tried the procedure as an alternative to mine and it does not work. But it is written by The Legend that is Ken Wells, and presumably he had MMTTY in front of him and he was testing his settings as he wrote the document. So it must work. But for me, as a lesser mortal, I am not capable of understanding.
    You are welcome to my help, not that it does any good, at any time. Yes, I updated AetherSDR. Some important fixes this time. More complexity, features added that I'll never use, same TCI issues still. But I'm sticking with it. Regards, Erik.
  • IK8HCG
    IK8HCG Member ✭✭
    Hi Erik
    Ken helped me clean up everything related to the previous version (4.1.5), which I had uninstalled incorrectly by using Revo. I even sent him a screenshot of my Device Manager with hidden files visible so he could verify the new DAXV2 files. One thing is certain: there is a breakdown in communication somewhere, and there are three of us hams experiencing the same issue. As users, we followed the MMTTY user guide. For now, I’m giving up, partly because I suspect MMTTY itself might have a problem; it’s not even communicating with SDRbridge for the skimmer something that worked fine with version 4.1.5. We’re waiting for a helpful ham who uses this configuration to step forward.
  • IK8HCG
    IK8HCG Member ✭✭
    Eric
    Can you tell me what you find in this folder?
    1.png 76.2K
    Hello. My folder contents are exactly the same - same files with same dates and sizes.
  • IK8HCG
    IK8HCG Member ✭✭
    edited October 5
    TNX
    We're on VHF chatting with friends to figure out where the problem lies.
    Every time I load MMTTY, I get a sound card error with a different number.
    I’ve also just received an email from Ken confirming that DAXV2 works with MMTTY using the procedure he attached.
    • Close SmartSDR, DAX, CAT, and MMTTY .
    • Reboot the computer
    • reboot the radio
    • Reopen SmartSDR, DAX, and CAT and properly "Connect" them to your computer.
    • Open MMTTY and check the configurations for Radio Control and Sound Card.
    Erik, give it a try too.
    1.png 447.1K
    Well, I don't have problem using the settings that I use and which I showed you. Using his settings, using CAT instead of PTT, does not work even after going through the procedure you list. If it works for you I would be surprised. There is no need for CAT with MMTTY. It does not need to know any frequency.
