Two Radios
I have the SO2R Tuner Genius. Is it capable of using two radios, one on TX A (an 8600, Power Genius combo), and the other on TX B with one antenna on Ant A?
Hi
The Tuner Genius SO2R is designed to have one input pass through the tuner and out it’s corresponding output. The other input and output are connected straight through, bypassing the tuner circuit. The switching matrix inside allows A in to A out and B in to B out. There is no capability to have either A to B or B to A.
To accomplish what you want, you would need to use the Antenna Genius 2x8 antenna switch. The AG provides the antenna matrix switching you desire. It allows up to 8 antennas to be switched to either radio. Both radios cannot use the same antenna at the same time.Let me know if you have any additional questions.
73Dave wo2x
Presale Support
- 688 The Flea Market
- 105 Aurora
