FHM-3 HANDSET HOW TO HOOK MAESTRO C ****?
HAVE THE Y-CABLE HAVE THE FHM-3 AND MAESTRO C The document that Mike VA3MW dId not dump enough for me. The Elbow connector on the handset plugs into (BLANK) with the phono adapter plug into (blank) then plug the y-cable plugs into maestro at the (blank)
don't laugh at me or make bad comments I have been blown up in combat so many time its hard to comprehend documents sometimes
Jim
WU5E
    edited December 2024 Answer ✓
    Hi Jim, the Y cable male end plugs into the lower left hand jack labeled HDST (next to the external power jack).
    The mic elbow connector plugs into the Y cable labeled as TRS Mic.
    I think that you also need a 1/8 inch mono male plug to RCA female adapter to plug the RCA PTT plug into (on the FHM-3 cable). That adapter plugs into the PTT jack just above the HDST jack.
