An annoying problem
James Green
in Maestro
I have had the pleasure of using my new Maestro "C" as one of the early shipments.
My microphone connection (FHM-3) is via the adapter cable provided by Flex. All systems worked correctly until recently. The transmitted audio had interruptions. You might know this had to be a problem just when I was to use it at a special event station.
The problem: That 4 circuit plug was not making proper contact in the socket. I was just one step away of preparing to send the Maestro "C" back to Flex.
Upon careful examination of the plug on the adapter cable, I discovered the plastic shell had migrated closer to the tip of the connector preventing it from adequately entering the socket. Now one must insert the connector by carefully pushing the cable to the point that insures proper insertion. Great amounts of frustration solved. Fault, slipping plug shell.
I hope this story will help someone else that may have the same problem
James Green WB3DJU
Tags
James Green WB3DJU
Tags
- 408 Community Topics
- 705 The Flea Market
- 206 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
