6600 -> 8600
GI4NKB
Member ✭
I'll be taking delivery of an 8600 in a few days time to replace my current 6600, can I simply unplug the 6600 and replace it with the 8600 or is the some sort of best practice I should follow to avoid any issues?
Best Answers
Assuming that your 6600 is on 3.8.20, I would export your profiles first. Then just plug everything in the way it was with the 6600 (plus the GPS antenna). Turn it on and import your profiles and you will be all set.
Thanks Len, I'm currently running 3.8.20 and I think I've only one microphone profile saved as I use my 6600 primarily on CW and the various digital modes so no issues there :smile: It seems like a simple swap out is all that is required. Cheers!
73, Frank GI4NKB0 -
Hi Frank, another reason to move the profiles to your new rig us to get all of the persistence values. There are a bunch of things that you have adjusted at one time or another that are nice to have when you fire up your new rig.
Enjoy your new radio!
- 105 Aurora
- 974 Genius Products
