SSDR doesn't see Flex-6700
Hi everyone,
I wanted to work with my Flex-6700 with SSDR under MacOs. My radio was always visible but recently when trying to connect there is only a demo. I do not have a firewall or other security enabled. When I send a ping Flex responds. I tried to manually enter the IP address of my Flex and once the connection was successful. Today the same problem again. Has anyone had this problem? I am working on Sequoia 15.1.1. Win10 connects to the radio without any problems.
Slawomir
  • K3SF
    K3SF Member ✭✭✭
    check
    privacy /security network setting
    also turnoff firewall
    Paul K3SF
  • David Decoons, wo2x
    try this (from memory).
    Instead of clicking on connect, try either command-click, or control-click.
    I remember with my M1 Mini I had to do that then when it showed the radio, there is a checkbox to make it the default radio.
    73 Dave wo2x
  • Slawomir
    Slawomir Member ✭✭
    Hi,
    I have tried all possible settings in MacOs and also in the router. Unfortunately, Flex-6700 is not visible in MacOs. Marcus - the creator of SSDR did not help me either. Due to the PV installation, I had to connect my Asus router with a second router in a Mesh network so that the inverter would be visible in the PV application. Marcus suggested that the Mesh network is unstable and that could be the problem. But if everything works correctly in WIN10, why is there a problem on MacOs? I have to regretfully give up working Flex-6700 on MacOs.
    Best regards,
    Slawomir
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited December 2024
    I run my intranet / Internet on WiFI-6 ASUS MESH Network with 4 Routers in the home and Shop, When I run my station on my MAC or WIN PC's I have NO problems connecting to my Flex6700 so unless you have some settings on your Routers set wrong so I don't think it would be your ASUS Mesh network.
    I would look for a problem with a 3rd party firewall, VPN or other software issue especially if you can connect to it with your WIN10 installation.
  • Slawomir
    Slawomir Member ✭✭
    Hi, today I also noticed an interesting relationship. When I turn off the SSDR icon slider in the system settings - privacy and security - local network and turn it back on, the radio is visible and connects without a problem. After restarting the computer, I have to do it again for Flex to connect. Doesn't this look like some kind of Sequoia bug? Slawomir
  • K3CDY
    K3CDY Member ✭✭✭
    Good observation. I have seen this type of behavior on macOS with several other applications, and without exception, the issue was a problem with the application itself, not macOS.
  • Mike WA7IJV
    Mike WA7IJV Member ✭✭
    Hi Slawomir,
    You said you have no firewall. Does that mean you turned MacOS Sequoia's incoming firewall off?
    It is controlled via System Settings > Network > Firewall. By default, it is "on".
    If your Mac has it is set to "on"…
    MacOS Sequoia apparently has incoming firewall issue affecting UDP packets (used for Flex/Mac communication). Some have noted that if MacOS incoming firewall is turned off, it seems to resolve the issue.
    I tried it on my 15.1.1 backup Mac mini. Seems to work. And, fails when I turn MacOS incoming firewall back on.
    I prefer operating with MacOS firewall on, so not a solution for me. I'll wait for more Apple bug fixes.
    But, maybe that "on" / "off" test might help with your mystery?
    Mike WA7IJV
  • Slawomir
    Slawomir Member ✭✭
    Hi everyone,
    My problem has been solved. Apple Support advised me to delete some files in the network library. There were remnants of VPN configuration after cloning the system from the previous iMac. The next Sequoia update should improve the network performance. Thank you all for your help and kindness.
    73's
    Slawomir SP6DLO
