RTTY and split operation
Have been searching on how to use split with RTTY. Very handy when trying to get through a pile-up. So far all things I've tested, always seems to revert back to sliceA i.e. only way to have the transmitter off-set is by using XIT, which is not the most ergonomic way.
I have tried Fldigi, N1MM and SDC, but have not been able to configure so I can receive on one slice and transmit on another. Any suggestions??
/Lasse SM5GLC
Best Answers
    Answer ✓
    Hi Lasse, try this:
    Open two slices, A and B (not using the Split button)
    Close slice A
    Click the Split button on B
    This will leave you with receive on B and transmit on A. I haven't actually operated this way, but it looks like it would work. If you have a 6600 or 6700, I am not sure if you need to open the other available slices to force it to pick A.
  • Lasse SM5GLC
    Lasse SM5GLC Member ✭✭✭
    Answer ✓
    Len,
    thanks for the tip! It works, just tested with Fldigi! Amazing, I would never had figured this out by myself :)
    Lasse SM5GLC Flex 6500
