Can a “MultiFlex Audio Monitor” button be added?
When two remote users are operating a Flex radio via MultiFlex, they can’t hear each other when transmitting unless they enable “Local Audio Monitor”. But then, they also hear themselves when transmitting which can be problematic for a few reasons. It would be nice to be able to monitor the other MultiFlex user when they transmit without hearing oneself when transmitting.
  • n7sln
    n7sln Member
    Does anyone have any thoughts or comments about this request, or ideas for a work around to this issue? Thanks!!
  • Russ Ravella
    Russ Ravella Member ✭✭✭
    edited November 2024
    Definitely sounds like a good idea. It wouldn't apply to my operations but clearly would to others. But I have to say, given Flex is slow to address these kinds of things, if I could only pick one monitoring issue for Flex to address this wouldn't be it.
    The voice mode monitor function in the Maestro still loops through the radio and back rather than simply passing from the mic input to the audio output within the Maestro itself. This results in such large latency that the monitor function in the Maestro is essentially useless. Being such a basic thing, you'd think they would have fixed it in a f/w update if that's possible, or at least in the "C" version if it isn't since it's been an issue for years. Seems like an even more urgent issue to me.
    73 Russ KR6W
