Does SmartSDR for iOS support DJ2GO2 as a Midi device?
I've just started using SmartSDR for iOS in addition to using SmartSDR for Mac.
In the latter case, I use a DJ2GO2 controller to provide a great control surface. I can see that SmartSDR for iOS supports midi, but the info doesn't say which midi controllers.
Before I stump up £5.99, does anybody the answer?
  • W0MET
    W0MET Member, Unconfirmed ✭
    https://community.flexradio.com/discussion/8026301/using-dj-controllers-with-flex-6xxx-solution check out this article on this device. It might answer your question.
  • m5kvk
    m5kvk Member ✭✭
    Thanks, @W0MET. I use the DJ2GO2 successfully on the Mac, but this is specifically for the iPad.
