Loopback and xdax on a Mac
2»
  • K3SF
    K3SF Member ✭✭✭
    hey Chris….
    yep that was it…once i gave Terminal full disk access away it went…took less than 30 seconds to get it done…
    have to write it up a nice concise process to give xDax microphone privileges…
    it works…
    Thanks for the magical incantations…
    i was almost ready to get out the rubber chicken and swing it over my head three time ;-)
    Paul K3SF
  • K3SF
    K3SF Member ✭✭✭
    edited January 2025
    i consolidated the info here for fixing xDax microphone access…if anyone needs to save this to their computer for future reference
    chris i think i captured it all in proper sequence
    no rubber chicken is required. ;-))
    Once again Chris Thanks…
    now i can run from the main screen of my 6600m any digital modes and/or do band surveys or listen doing pedestrian mobil with my iphone …great to have it all back and using Sequoia MacOS too
    Paul K3SF
  • ChrisAC9KH
    ChrisAC9KH Member ✭✭
    Paul, glad you got it working as expected again! Sorry I didn't pick up on the fact that you guys were running Terminal sandboxed. That is, after all, the default in MacOS. It's just that I use Terminal for everything so it's one of the first changes I make when I fire up a newly installed system, and it just didn't dawn on my until I saw the screenshot with the error.
    That is an excellent summary guide, hope it's useful for other folks who might run into this problem.
    I don't know how long xDAX/xCAT will continue to work as Apple continues MacOS releases. They are both x64 binaries and right now they run on M-series silicon with the Rosetta2 translator. I suspect Apple will discontinue that after awhile like they did with the switch from PowerPC to x64 back in the day. Then somebody will need to get the source code and rebuild them for ARM64 (M-series).
  • Mike WA7IJV
    Mike WA7IJV Member ✭✭
    Footnote…
    Shortly after the xDAX success, I launched Loopback to view my audio devices, and was surprised when it instead asked “OK to give ARK mic access?”.
    I allowed, and ARK was back in the mic list. But, my Loopback audio devices were now gone.
    During the xDAX manual insert activity, I noticed the Sequoia microphone list was much shorter than on Sonoma.
    Looks like the Sonoma-to-Sequoia 15.3 upgrade cleared the microphone list. Possibly precipitating audio device issues when ARK lost mic access.
    Devices recreated, all working again.
  • K3SF
    K3SF Member ✭✭✭
    hi Mike
    similar not not the same…all my loopbakc devices where there but turned off…open them up and turned them on again…
    Paul K3SF
    Screenshot 2025-02-01 at 3.10.24 PM.png Screenshot 2025-02-01 at 3.10.14 PM.png
