AG with two radios
Jay
I have not seen this behavior. What happens if you configure radio 2 to be the AG radio A? Don’t switch RF cables but see if the app drops out with only port A of AG app configured for ant1 of radio 2.
If that is stable in app, then change app so that port B is configured for radio2 and port A has no radio. See if it is stable. If so, your RF cabling should be in place from Ant1 of radio 2 to amp2 to tuner 2 to AG port B. Now try transmitting at power level you use in contesting to see if the app on PC2 drops out. If it does when transmitting, then RF into the PC or network cable to PC2.
This should be fairly easy to isolate by switching things between position 1 and 2. I have run my 6700 on port A of PG, TG and AG and other different radios on port B for testing without an issue using the VA6AM bandpass filters (triplexer for 10,15,20 and diplexer for 40/80).
73 Dave wo2x
- 692 The Flea Market
