2 Antenna Switch 8 + 2
I have for sale 2 Antenna Switch 4O3A both News never use and open …450.00 each plus shipping..
Eight antennas to two radios high isolation antenna switch.
Features:
  • Built in hardware interlock system. Same antenna can not be used on both radios at the same time.
  • 4kW power rated.
  • Wire controlled by a mechanical switch or Station Genius, SAC X or any other band decoder.
  • Mechanical antenna switch, Station Genius and SAC X are not included but can be purchased separately.
  • Control connectors on bottom of the case makes installing, replacing and repairing fast and easy.
  • LED control diodes for visual monitoring of device.
  • 4O3A style high isolation.
  • Easy to install anywhere in the shack.
  • Input conectors are SO 239 or N type conectors.
  • Compatible with all +12V source driver band decoders.
  • Factory preset on +12V signals.
  • Unselected antenna ports are grounded.
  • Without power all antenna ports are grounded.
  • Each device is individualy trimed and tuned for best performance.
My email is …..monvaz2008@gmail.com
Jim-WP3A
