Missing Bands in Band Selector
I just noticed that 160M and 40M are missing from my left side Band Selector. I did a factory reset including persistence on my 6500 running SmartSDR for Mac version 2.9.31 but the bands did not return. I can manually enter a 40M frequency, and switch to a missing band frequency from digital programs. This is not a major issue but I would appreciate any direction in getting the bands back in the quick select list.
Thanks, Ron
FWIW you're not the only one. I am missing 160, 40, 17 and 10
Gareth, M5KVK
Can you post a screenshot of what you are seeing? I wonder if you just need to move the window over some if you have it all the way to the left side of your monitor. On mine the popup window goes wide.
I believe you found the same feature as me (I expect we are not the first…). I finally discovered that if you line-up the main radio window just to the right of another window, or on the side of the screen, the leftmost column of band labels extends beyond the visible screen. Perhaps Flex could make a simple programming change to stop this behavior.
Ron
