Apple tablet with SDR Smart link
My Smart link works on my home WiFi but can not link to my Apple tablet.
I see SmartLink FLEX-6500 (UPnP) with the Green light on but will not link.
Does anyone know how to proceed?
  • Neil D Friedman N3DF
    Not exactly sure of your situation. Don’t need SmartLink to connect on your home WiFi.
  • David Decoons, wo2x
    Risky
    Can you elaborate on your setup? Are the radio and iPad on same network
    How is your network configured? Cable modem/fiber gateway? A separate router? More detail is needed to assist you.
    Dave DeCoons
    Presale Technical Support
  • Val  DM1TX
    Val DM1TX Member ✭✭
    Not clear if it has worked before or if you set it up now. Marcus, the software developer has a very well written manual. I suggest you look at the Smartlink setup section. On my 8th gen iPad (with LTE sim card) is working flawless at home or outdoors. I am managing a 6500 and a 6400 in different locations. 73
  • Risky
    Risky Member
    I am running a Flex 6500 iPad PRO Version 7.5.1
    When I start up SDR on the iPad on my Home network I get Two Radio options.
    One
    SmartLink (inblue) Flex-6500 (UPnP)
    57.134.156.12
    Two
    Flex-6500 0/2 in use Risky
    192.168.40.104
    This setup I want to use my Hotspot, Phone Telus 5G I get this,
    The same two SmartLink Flex-6500
    I click on it and will not bring up the radio on the screen.
    I had an iPhone 12 that worked well but won't work on the iPad.
    I check to see if I am logged to SmartLink and it says Yes.
    What am I doing wrong?
  • Val  DM1TX
    Val DM1TX Member ✭✭
    i believe I had this issue once with the iPad. if it show that you are logged on the Smartlink and still not connecting I would log it off and set it up once again on the iPad. I would but just do it over the 5G so with wireless off if you are home. This way you would know if it works. Have a look here too: https://documents.roskosch.de/smartsdr-ios/index.html#document-common/99_common_issues-ios
    73 Val
    Risky,
    Can you connect on your home network but not on Telus cellular?
  • Risky
    Risky Member
    Yes, I can connect to Home network no problem .
    Then it sounds like your cell provider is blocking VITA49 traffic. Here in U.S. T-Mobile is doing it.
