Tuner and IC-7610
W0NBC
W0NBC Member, Unconfirmed
I get "no band data" when I Hit the tune on the APP. I have the CIV enabled checked, Baud 9600, 8N1 Civ 0. software seems to work fine. TNX
Waiting for the 8400M!
  • W0NBC
    After much experimentation I found all you need to do is type in the numbers of the CIV address for the IC-7610 which is 98h but leave off the "h" and all works perfectly.
  • David Decoons, wo2x
    the h just indicates the number is in hex. It is not part of the actual number.
    73 Dave wo2x
