8400M NR NB improvements ?
KL4QG
KL4QG Member ✭✭
I’ll only buy if they improved the NR NB and Notch filtering
Any news on this
Joe in Alaska
KA2ZSD
  • KL4QG
    KL4QG Member ✭✭
    I pre ordered 8400M
    Joe
    Alaskan Joe
    KA2ZSD
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    So Joe… what convinced you to pre-order??
  • Al K0VM
    Al K0VM Member ✭✭✭
    Flex has indicated that improvements in NB NR NF will be possible with additional processor power in the 8000 radios but do not expect that to be in the initial versions of the software.
    AL, K0VM
  • KL4QG
    KL4QG Member ✭✭
    I wonder why we have wait I guess NR NB Notch filtering less important upgrade
    Thank U
    Joe in Alaska
  • Trucker
    Trucker Member ✭✭✭✭
    Joe, the Noise Reduction, Notch Filter and Noise blanker are done in the firmware and software of the radio. Until they update SmartSDR in the radio and on the pc, those features will work the same as they currently do. The new hardware in the radios should allow for better processing of DSP functions. But, still it will depend on what type of processing ( algorithms) the developers use. If they use something like Warren Pratt's WDSP library's Noise Reduction 2, then Flex users could get DSP performance similar to NR2 in Thetis. That would be a fantastic improvement over the current Noise Reduction in SmartSDR. ( which is itself is quite good. Just not on the same level as NR2)
    Unfortunately, it would appear that this kind of improvement will only be available in the new hardware. Which is unfortunate as I firmly believe the current generation of Flex radios ( 6000 series) has hardware that is more than capable of handling the processing needed for Noise reduction 2. But, Flex Radio may have to sacrifice some other things in SmartSDR to make it happen.
  • KL4QG
    KL4QG Member ✭✭
    I had 6400M and 6600M both nice radios
    I sold and went to 890 Kenwood that radio disappointed me in NR area it trouble bad
    Perhaps it’s best I look for nice used 6400M or 6600M I’m not interested in using the radio with a computer I don’t have a home computer or Wi-Fi at home
    Knowing me I just keep my pre order going on 8400M
    Joe
    I enjoy everyone input
