Antenna genius as coax disconnect
does anyone have experience using the antenna genius products for a coax disconnect and isolation device?
    Hi David, the 4O3A 8x2 switch isolation numbers are really good. As far as a coax disconnector, it depends on what you are after. If you are looking for bullet-proof lightning protection, this is not it. If you are looking to protect receiver front ends from nearby transmitted signals, this will definitely do it.
  • David Smith
    David Smith Member ✭✭
    thank you
