Technical Update
I received an email today from Flex and part of the message was antenna Genius update 4.1.8. Has this been approved for use? I know I had a previous v4 in use and there was a problem and was told v4 had not been approved for use and should be using v3. Just checking before I start clicking.
Hi Mike,
Yeah, it has been approved. But the thing is, you need to be sure you're using the right Tuner Genius f/w with it. They're kinda paired. General comment: Flex has FINALLY started including the "approved" Antenna Genius f/w version including link at the top of this community page. You can see them all up there now. They used to not include the AG since it's basically handled directly by 4O3A. The ones listed for everything are the ones approved and recommended.
So, short answer, TG v1.2.11 WITH AG 4.1.8 is offically approved. As an aside, I've been using them for a few weeks and they seem to work great even juggling SO2R and MultiFlex at the same time.
73 Russ KR6W
Thanks!
Thanks I went through that. Things seem to be working now.
- 322 Shack Infrastructure
- 227 Networking
