Maestro C Overview page on web site
AA1SS
AA1SS Member ✭✭✭
This is on there…
  • Microphone 1: Pseudo-balanced 8-pin RJ-45, dynamic or electret compatible
Where is the rj-45 on the Maestro C
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    According to the Quick Start Guide, it should be on the rear panel, right side, just below the Line In jack….
  • AA1SS
    AA1SS Member ✭✭✭
    Maestro C does not have a RJ-45 mic Jack
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    The Maestro user guide shows all the connections for the A, B, and C models.
    https://www.flexradio.com/documentation/maestro-user-guide-pdf/
  • VE7ATJ_Don
    Hi AA1SS — According to the Maestro User Guide, you are correct, there is no RJ-45 mic connector on the Maestro C. It appears the only MIC input is the TRSS jack (at least, I couldn't see any other mention of mic input under the C unit…)
    Maybe what you read was referring to an A or B unit???
