Maestro Memory group channel sorting
Hi Folks , many times I wonder if it,s possible to sort the memory channels bij frequency band and from low frequency to high .
when the list of memory channels is getting bigger it would be nice to sort your memory channels in the windows pc client and also in the Maestro to put the channels where you want them to be , I understand that dragging lines is not easy in touch screen like maestro but maybe when you can drag the lines in the pc client and the Maestro automaticly takes over the correct sequence it would be easyer to find back your memory channels .
Maybe you can do something to make dragging easy? or is it allready possible ?
Kind regards Rob
PB2RVS
