Antenna Genius 8x1with more than one radio
My question is can you use the 8X1 in reverse I have several radios and one antenna I use for all of them and I use a manual switch but would like to use the 8X1 to do this. I also have a SDRPlay I would like to use in receive and have it switch out during TX of any of the radios.
Thanks Dennis KM6DF
  • David Decoons, wo2x
    to address your first question, yes, you can run the 8x1 in manual mode to select up to 8 radios to one antenna out. Just set each antenna port in AG to none for both RCX and TX. The issue will be your mic, speakers, amp key out switching.
    Another alternative which allows single mic , speakers, common amp key out and RF switching is W2IHy, station control. Not sure on total of radios but it may be worth a call to Julius. His support is excellent.
    https://w2ihy.com
